Hi, I have an API which returns JSON data. So im using the JSON API Grafana Datasource by SimPod.
My data connection/dashboard:
- Im connecting to the API path of where all my sensors are.
- When in query of a dashboard I get the available metrics for either all sensors (*.metric) or an individual sensor (sensorname.metric).
- I have created two panels of type “table” where I in the first one selected *.temperature and in the other selected *.humidity (same sensors have both metrics).
- When in edit mode everything seems to work fine.
My issue:
When loading a fresh start of the dashboard (which has these two panels) I get NoData in both.
*After pressing the “refresh button” some data might get returned but not guaranteed (also inconsistent returns between the two panels).
- If i go into edit mode of each panel the data seems to get queried and is visible when going back to dashboard.
- However, the sensors being returned between the two panels are inconsistent, I get different sensors in the two panels.
*After several attempts of going in/out of edit in each panel I might be lucky and retrieve data of the same sensors.
What might be causing this?
