Hello, I’m trying to display dashboards on my (localhost) website but nothing is showing, i modified the parameter in the ini file to allow display but it doesn’t work.
See a screenshot of what i get instead of the dashboard
Did you setup authentication or are you using anonymous mode ?
Good Luck
