Dashboad vertical time layout of multiple panels
I’m currently trying to set up a new dashboard but the layout is “off” when using multiple panels below each other. I saw that i can set a fixed width for the legend on the right side, but on the left side the unit “messes” up the layout for the graph.
Is the a way to get multiple panels of the same graph size, so all x-axis-ticks are exactly lined up?
Left side is not same:
Right side works with legend width override:
I’m not sure this is possible–sorry!
