9.4.7 on raspi_pi -
I need a bar chart showing the summed daily precipitation amounts: 24.07: 4mm, 23.07: 7mm, 22.07: 2mm -
from(bucket: “data”)
|> range(start: -7d, stop: now())
|> filter(fn: (r) => r[“_measurement”] == “WeatherSensors”)
|> filter(fn: (r) => r[“STATION_ID”] == “01”) |> filter(fn: (r) => r[“_field”] == “rain”)
|> aggregateWindow(every: 1d, fn: sum) -
What happened?
The dates on the x axis only fit for today, otherwise it is shifted by 1 day (for yesterday it also says 24.07.) -
The correct date should also be displayed for the other days
