Customizing Tempo Service Graph
    Grafana v10.1.2
Is it possible to create a custom node graph like Tempo’s Service Graph. I tried but there is no example online. The Tempo’s service graph can visualize dependencies between services using metrics_generator. However, I want to create an endpoint level dependency between services (endpoints name visible on graph, see following picture), as well as avg response time, requests per second, failed request rate for each endpoint.
Thanks in advance.
