Custom variable format
Is it possible to ship a new variable format with a datasource plugin ? As in https://grafana.com/docs/grafana/latest/variables/advanced-variable-format-options/
I don’t believe that it’s possible unless you start parsing the templates yourself. Looks like adding one to the registry isn’t that difficult, in case it’s not too obscure of a format :slight_smile:
What do you mean by “adding one to the registry” ?
The format I’d need for my riemann datasource would be something in the likes of the distributed flavour:
      description: 'Multiple values are formatted like `or variable = "value"`',
      formatter: ({ value }, variable) => {
        if (typeof value === 'string') {
          return value;
        value = map(value, (val: any, index: number) => {
          if (index !== 0) {
            return "or " + variable.name + '" = "' + val + '"';
          } else {
            return val;
        return value.join(',');
