Grafana Version: 7.5
OS: Ubuntu 20 -
I have followed this tutorial to create a custom panel plugin. The panel has a series of options select options which should cascade as your select them. For example:
Option 1: Vehicle Make
Option 2: Vehicle Model
I would like for the option 2 to be driven form the selection of option 1. Is this possible using Grafana basic panel options?
I notice that the “showIf” property can be driven by previous option responses. I tried to use this but with no success.
