We need help on fetching the configurations for OpenID {CROWDID} .
OPENID provides only the endpoint without any ClientID or ClientSecret
http://192.168.56.101:8095/openidserver/users/syedshaheazaliad
So what configurations i should add in grafana.ini
http://jagadesh4java.blogspot.com/2011/11/liferay-with-openid.html this is best example
I found solution by myself by creating my own custom RESTAPI php script .
User will login to httpd and httpd will redirect to my custom script to validate the user from CROWD and if the user is available then it redirects to Grafana
REFERENCES LINKS:
If you want to secure your webpage with a simple authentication you may want to use an external authentication backend. For example, you already have some authentication in PHP in an existing system, then here's how to extend Apache's HTTP Basic Auth...
Grafana Auth Proxy Guide
https://developer.atlassian.com/server/crowd/crowd-rest-apis/
