Creating Influx data source with Ansible - TLS Skip Verify fails to initialize correctly
    Grafana 8.3.3 on RHEL7
    Trying to create an influx data source with ansible
    Ansible playbook. Role looks like:
  • name: Create data source
    uri:
    url: “https://{{ grafana_instance }}/api/datasources”
    url_username: “{{ grafana_admin_user }}”
    url_password: “{{ grafana_admin_pwd }}”
    method: POST
    force_basic_auth: yes
    body_format: json
    body:
    name : “{{ item.dsname }}”,
    url : “{{ http_prefix }}://{{ item.influx_vip }}:8086”,
    database : “{{ item.dbname }}”,
    type : influxdb,
    access : proxy,
    user : “{{ grafana_user }}”,
    jsondata : { tlsSkipVerify: “true” },
    securejsondata : { password : “{{ grafana_password }}” },
    validate_certs: no
    with_items:
    - “{{ data_source_info }}”
  • What happened?
    Data source is created. The TLS Skip Verify button is set to ‘true’. However, when I test the data source it says “Bad Gateway”. Toggling the TLS Skip Verify flag to false, back to true, then save and test - the data source works. What am I missing in initializing that flag?
    Expected the data source to work. Instead, I need to toggle the Skip TLS Verify flag manually.
    See ansible role above
    Don’t have access to the log files at the moment. I can probably get them if necessary.
    But toggling the one flag makes it work. Looks like the flag is set in the GUI but not active.
    The error from the GUI was “Bad Gateway”
    No - used a combination of ansible URI documentation and looked at various Grafana and influx docs
