Creating a plugin to change the Measurement name of InfluxDB data dource
I would like to use InfluxDB as a data source where the Measurement names are all numbers.
At this time, it is difficult to know what items represent, so I would like to change the display of the item names using the mapping between numbers and item names that I have in another database.
The measurement name in InfluxDB is determined by another system and cannot be changed.
Can I create my own plugin that does this?
@ritsu2891 this might be a case where you want to contribute to the influxdb datasource plugin (which is part of the grafana).
Grafana’s plugin API doesn’t support plugins modifying the behaviour of other plugins.
Thank you for your kind reply.
I did some research on my own and found that it is not possible to change the behavior of the Grafana native InfluxDB plugin with a plugin.
Since I need to address the above immediately, I decided to first create my own InfluxDB data source as a plugin that allows me to change the item names as described above.
I am confident it’ll take you less time to open a PR in grafana than recreate all the influxdb plugin functionality. You should give it a try.
Also, just to add my $0.02, if one were using Flux (which @ritsu2891 does not appear to be using), I believe you could rename the measurement in your Flux query using the map() function to modify the _measurement field in the results. Something like this:
from(bucket: "your_bucket_name")
  |> range(start: -1h) // Adjust the time range as needed
  |> filter(fn: (r) => r._measurement == "74059804712109356")
  |> map(fn: (r) => ({ r with _measurement: "Item_A" }))
Hi, I wonder how you’ve done it? I actually need this too.
Regards,
Henjod
