Hey,
I use InfluxDB 2.5 as OPENHAB persistence service.
OPENHAB saves every data with two columns:
“_measurement” where name of item is saved
“_fileld” where it is always “value”.
So now in Grafana when I want to have two measurements shown on one graph I have two queries:
from(bucket: "openhab_db")
|> filter(fn: (r) => r._measurement == "pompa_moc")
|> filter(fn: (r) => r._field == "value")
|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
|> keep(columns: ["_time", "_value"])
|> sort(columns: ["_time"])
and
|> filter(fn: (r) => r._measurement == "pompa_dzis")
|> filter(fn: (r) => r.item == "pompa_dzis")
As You can see they have same r._field . And this is big problem. Because now I cannot make any overrides for one of this two queries. When I want to make any overrides I can make it for fields with names, and all fields have the same names…
Any idea how to override it?
