Creating a LogsReceiver in Promtail for Loki
Hi, I am new to Loki and currently want to configure an “azure_event_hubs” source for a Loki Microservices deployment.
I am not sure how the LogsReceiver needed for the “forward_to” attribute gets configured.
Is there a Promtail configuration yaml I can refer to?
Thanks a lot!
I think I found out why I did not need the forward_to / logReceivers. I will add a detailed comment/answer how I configured it
So the configuration looks like below.
As long as no Grafana flow is needed, the forward_to attribute is not needed either.
job_name: azure_event_hubs
azure_event_hubs:
  fully_qualified_namespace: ehns.servicebus.windows.net:9093
  connection_string: connection-string
  event_hubs: eh-name
  labels:
    job: azure_event_hub
relabel_configs:
  - action: replace
    source_labels:
      - __azure_event_hubs_category
    target_label: category
