we have a Grafana (grafanatest) instance with Prometheus/Loki/Promtail running on a Windows Server 2019.
Now we want to forward Windows Eventlogs from a Remote Host (plswinsrv2012r2) to our Loki Server (grafanatest)
I’ve installed via nssm the promtail service on plswinsrv2012r2, because the promtail instance is a Server and Agent aswell. Where do i put the Destination-IP-adress in the config file to forward logs to the grafanatest Server.
Promtail-Windows.yaml (plswinsrv2012r2)
Preformatted textserver:
http_listen_port: 9080
grpc_listen_port: 0
clients:
scrape_configs:
- job_name: windows
windows_events:
use_incoming_timestamp: false
bookmark_path: “./bookmark.xml”
eventlog_name: “Setup”
xpath_query: ‘*’
labels:
job: windowsPreformatted text
Or should i configure the Target on the Grafanatest Server if yes, where should i type in the targetadress.
grpc_listen_port: 0
clients:
scrape_configs:
- job_name: windows
windows_events:
eventlog_name: “Security”
xpath_query: ‘*’
labels:
KR
Alex
