Grafana 8.5.15 -
I have an existing panel, which is querying data, and applying a JSON Data transformation.
I’d like to share a message to Slack, containing some properties of the JSON data. -
Tried to create an alert, but cannot transform data in Alerts edition
Also tried to reuse the panel’s data to another graph panel, but cannot find how to make it work -
Share query results with another panel | Grafana documentation
the instruction is wrong, but I also do have the same problem tho
