Create Alert button doesn’t work even with graph, worked perfectly with 6.7.1. As a result, I m not able to use Alerts at all
It is the same for me, v7.4.3 only allows creating alerts with “Graph”
can anyone pls help me here with some guidance?
Getting below error/behavior when I m running the grafana on docker container(version - 7.4.2s ):-
- Create Alert button doesn’t work (error: Uncaught TypeError: Cannot read property ‘_enableAlert’ of undefined)
- display properties for the Graph are not available
everything works fine on 6.7version
I figured out the issue. it is not working on chrome but works fine in Edge
