Create a static metric using local.file
I have a file on a Linux filesystem that contains a timestamp. I would like to take that timestamp and create a metric with it that can then be used in Grafana.
Is it possible to create a static metric with Alloy? And then have that metric use the timestamp as a label or even the value?
This is what I have been trying so far:
local.file "update_timestamp" {
  filename  = "/var/log/update-timestamp"
prometheus.scrape "update_timestamp" {
  targets = [{
      "__address__" = "alloy.internal:12345",
      "timestamp" = local.file.update_timestamp.content,
      "__fake_name__" = "placeholder",
  forward_to = [prometheus.relabel.update_timestamp.receiver]
prometheus.relabel "update_timestamp" {
  rule {
    source_labels = ["__fake_name__"]
    regex = "placeholder"
    action = "keep"
  rule {
    source_labels = ["timestamp"]
    regex = "([0-9]+)"
    target_label = "__value__"
    replacement = "$1"
  rule {
    target_label = "__name__"
    replacement = "update_timestamp"
  forward_to = [prometheus.remote_write.default.receiver]
Alloy debug shows all the metrics with the timestamp label, for example:
  __name__="alloy_build_info",
  branch="HEAD",
  goarch="amd64",
  goos="linux",
  goversion="go1.24.3",
  instance="alloy.internal:12345",
  job="update_timestamp",
  revision="d3d7931",
  tags="netgo,builtinassets,promtail_journal_enabled",
  timestamp="{false 1749749967\n}",
  version="v1.9.1"
But there is but no new metric that I can filter on. So it appears that the relabel never happens.
Is what I am trying to do even possible?
I find using stage.metrics in loki.process to be the easiest way to extract metrics from log files (see loki.process | Grafana Alloy documentation).
That said, I don’t think you can explicitly set a timestamp for the metrics.
The file is not technically a log file. It just happens to live in /var/log. The file only ever contains a single timestamp, and only a timestamp.
File: update-timestamp
1749749967
I will look into loki.process. Thanks for the recommendation.
