Create a Cortex/Prometheus alerting rule
    8.1.2
    Create and Edit Prometheus rules using Grafana version 8 integrated alerting
    Attempting to add Prometheus as a data source when creating a rule
  • What happened?
    Prometheus does not appear on the list (but it is configured and working elsewhere in Grafana)
    I expected it to appear.
    I could, but which part?
    No
    No, they are incomplete. They say to use the legacy api, but not how.
