9.1.2 -
Configure and use Cortex ruler.
Use Cortex in
I have a Cortex stack running in production fine.
Adding a Prometheus datasourcehttp://cortex/prometheusorhttp://cortex/api/prom
Having a previously configured alertmanager backend linked with this datasource. -
What happened?
Ruler API enabled -
no -
no -
I’m limited to 2 links as a new user… I searched the doc and latest/alerting/alerting-rules/rule-list/
I found
https://github.com/grafana/grafana/blob/f3085b1cacef1a7cda5963320f116555b4389fa9/public/app/features/alerting/unified/api/ruler.ts#L97 (I don’t have such a rule)
https://github.com/grafana/grafana/pull/46771#discussion_r839359406
Which make me think Cortex ruler is not supported, but that’s not clear.
I have no idea why I can’t select Cortex when I want to configure alerts, what is supposed to enable it ?
