CPUUtilization metrics for an auto-scaling group shows only an aggregation
Latest Grafana on RHEL
Add a panel that shows CPUUtilization for each instance in an auto-scaling group
Please see attached screenshot
  • What happened?
Only one metric is shown on the graph
Multiple metrics shown on the graph, one for each instance
No
Tried many different things on the internet…
Please note the CloudWatch source is working fine. Also, when using metrics exported by Telegraf, we immediately see one metric pre instance, for example for disk usage.
Thank you very much in advance for any help!
Fabrice
Hi everybody,
So after some research, I am quite sure the problem is that the AWS/EC2 metric CPUUtilization has no dimension named AutoScalingGroupName . Consequently, we can’t filter on the AutoScalingGroupName for instances’ CPUUtilization .
Confusingly, autoscaling groups publish a metric also named CPUUtilization , which is an aggregate of the CPU utilization for all the instances in the group. Now this metric does have a dimension named AutoScalingGroupName , explained here, so when we filter based on the autoscaling group name, that’s the metric we are seeing, not the per-instance CPU utilization.
As far as I can see, the CPUUtilization published by AWS for each EC2 instance has only one metric: the instance id. That’s not enough for Grafana to filter on the autoscaling group name. In our organisation, we had to use a metric exported by an agent running on the instances.
Hey Fabrice , any new insight in this issue? there other option than export the metric using the agent?
