HI,
Is there any way, we can grep the cpu and memory usage for a specific process, i am using Grafana lateset version with telegraf and Influx DB, thanks for help in advance.
Thanks
Ravi
HI,
Thanks
Ravi
Hi ravi154.
I think you can use snmp for get cpu or mem by process. Data can post to InfluxDB or PostgreSQL.
Refer: http://www.debianadmin.com/linux-snmp-oids-for-cpumemory-and-disk-statistics.html or inbox me, i can advise specifically.
Thanks.
Hi @ravi154,
I think you can use the procstat plugin in Telegraf to do this.
The Procstat input plugin can be used to monitor system resource usage by an individual process using their
/procdata.
Link: Procstat paragraph in Telegraph documentation
More detailed doc: Procstat Input Plugin
