Hi
I am trying to create a table panel in Grafana. I have an ES index collecting data from DB using Logstash. My actual DB table consist of only 12 rows with status either as COMPLETED or PENDING.
I want to have a table which shows me the number of rows which are completed and number of rows which are pending.
I am doing that as:
Metric: Count
Group By : Terms status.keyword
But on doing this I am getting COMPLETED count as 630 and PENDING count as 7, which sum as the total number of hits in ES.
I am expecting results to be COMPLETED count 8 and PENDING count 4. Sum should never exceed 12 , as there are only 12 rows in my data.
I have scheduled the logstash config file to run every minute. So it is pushing data every minute into ES. The count I was getting is the sum total of all.
To solve it, the only solution I can see is Override the time to 1m in Time Range of the panel. So that I see the count of last collected data only and not the sum total.
I have the exact same issue…I get alerts because of the count shows as 0 if I use graph or stat visualisation but in table view I see hundreds of rows with two columns…one with the timestamps and one with “Count” where the value is 0…any help please?
