Count and group by day based on label value
    Grafana v9.1.4
    I’m collecting metrics about log files with filestat_exporter, and i would like to have graphic with the count of rotated logs per day based on values of the label path.
file_stat_size_bytes{fqdn=~“$fqdn”,path=~“/var/log/mylog-[0-9].*.log”}
so the path label has values like this:
/var/log/mylog-2023-03-18.0.log
/var/log/mylog-2023-03-18.1.log
/var/log/mylog-2023-03-18.2.log
/var/log/mylog-2023-03-18.3.log
/var/log/mylog-2023-03-19.0.log
/var/log/mylog-2023-03-19.1.log
/var/log/mylog-2023-03-19.2.log
How can i write a PromQL that would give me a bar graphic with the count of rotated logs per day based on the values of the label path?
Using the values above, the end result would be:
2023-03-18 → 4
2023-03-19 → 3
Welcome @mvrk
Have you explored all of the examples here?
Also, this question (and answer) seems similar to yours and may help get you started.
thank you, that post on stackoverflow really helped.
count by (path_group) (label_replace(file_stat_modif_time_seconds{fqdn=~“$fqdn”,path=~“/var/log/mylog-[0-9]..log"}, “path_group”, “$1”, “path”, ".-(\d{4}-\d{2}-\d{2}).*”))
