Grafana v9.5.2-cloud.1.f9fd074b -
Convert Nginx time format (<daynumber>/<monthname>/<year>:<hour>:<minute><second> <offset from utc>) to Grafana’s default time format. -
Using the data transformations feature. I have tried an input format ofDD\m\YY:HH:mm:SSandDD\M\YY:HH:mm:SS. -
What happened?
The month shows as January (01), or the output is blank. -
I expected the month to show as May (05) which is the month that shows in the raw logs. -
N/A -
N/A
