I have setup NetApp Volume latency alerts in Grafana.
Whenever an alert is triggered we get the latecny value in microseconds.
Is there a way to setup the alerts to convert latency in milliseconds and trigger notification?
[FIRING:3] Volume Top Average Latency ASE | NetApp Harvest 21.11 - cDOT (n1_aggr1_sata ntap-cluster-dev00 SY3 poller-ntap-cluster-dev00:13000 harvest ntap-cluster-dev00-01 critical ontap flexvol)
**Firing**
Value: [ var='B' labels={__name__=volume_avg_latency, aggr=n1_aggr1_sata, cluster=ntap-cluster-dev00, datacenter=SY3, instance=poller-ntap-cluster-dev00:13000, job=harvest, node=ntap-cluster-dev00-01, svm=ntap-cloud-vs2, type=flexvol, volume=ntap_cloud_vs2_00_sata} value=112998.3873015873 ], [ var='C' labels={__name__=volume_avg_latency, aggr=n1_aggr1_sata, cluster=ntap-cluster-dev00, datacenter=SY3, instance=poller-ntap-cluster-dev00:13000, job=harvest, node=ntap-cluster-dev00-01, svm=ntap-cloud-vs2, type=flexvol, volume=ntap_cloud_vs2_00_sata} value=1 ]
Labels:
- alertname = Volume Top Average Latency
- latency = 112998.3873015873
- aggr = n1_aggr1_sata
- cluster = ntap-cluster-dev00
- datacenter = SY3
- grafana_folder = ASE | NetApp Harvest 21.11 - cDOT
- instance = poller-ntap-cluster-dev00:13000
- job = harvest
- node = ntap-cluster-dev00-01
- severity = critical
- storage = ontap
- svm = ntap-cloud-vs2
- type = flexvol
- volume = ntap_cloud_vs2_00_sata
Any help is much appreciated.
