Is there a way to get XY chart code? Because I I cannot find it anywhere? I would like to make contribution.
its part of the grafana code base itseld not as separate plugim like geomap, time series, bar chart etc
Thank, yes I found the code in repostory under public\app\plugins\panel\xychart. So probably I can now make any modificaitons to plugin right? Just it’s confusing beacuse like you pointed out it’s not a seprate plugin but it’s code base.
Grafana has both core and external plugins. xychart is a “core” plugin (meaning it is part of the grafana core codebase) and as you pointed, its code is inside the grafana repository grafana/public/app/plugins/panel/xychart at main · grafana/grafana · GitHub
Your contribution is very welcomed!
you can see the general contribution guide and the developer guide to setup your environment to work in the Grafana code base
In case you are using Windows, you must use WSL for all the development of Grafana.
