Constant-arrival-rate executor not reaching target rate
Hi team,
Thanks in advance for reading.
I’m attempting to run a test that uses a constant-arrival-rate executor to reach 100RPS, but I’m consistently falling short of that target. I believe that I have sufficient resources for my testing environment to run this test, and I have been able to reach ~220RPS if I use the constant-vus executor, and ~140RPS if I instead set my target to 200 RPS using the constant-arrival-rate executor.
vCPU: 32
Memory: 64 GiB
Network Bandwidth: 15 Gbps
This is my test script:
import http from 'k6/http';
import {check} from 'k6';
import {SharedArray} from 'k6/data';
export const options = {
  discardResponseBodies: true,
  scenarios: {
    average_load_test: {
      executor: 'constant-arrival-rate',
      duration: '30s',
      rate: 100,
      timeUnit: '1s',
      preAllocatedVUs: 600,
      maxVUs: 1200,
const data = new SharedArray("urls", function () {
  return JSON.parse(open(__ENV.URLS_FILENAME));
export default function () {
  const url = data[Math.floor(Math.random() * data.length)];
  const response = http.get(url);
  check(response, {
    'response code was 200': (res) => res.status == 200,
My test output is as follows.
As you can see, I only reached 79.957096/s. There were no warnings regarding k6 running out of available VUs.
  execution: local
     script: /local/load_test/tests/k6test.js
     output: dashboard
  scenarios: (100.00%) 1 scenario, 1200 max VUs, 1m0s max duration (incl. graceful stop):
           * average_load_test: 100.00 iterations/s for 30s (maxVUs: 600-1200, gracefulStop: 30s)
     ✓ response code was 200
     █ teardown
     checks.........................: 100.00% ✓ 3001      ✗ 0
     data_received..................: 1.5 GB  38 MB/s
     data_sent......................: 11 MB   261 kB/s
     http_req_blocked...............: avg=32.24ms  min=223ns    med=5.5ms    max=347.45ms p(90)=97.05ms  p(95)=276.72ms
     http_req_connecting............: avg=11.97ms  min=0s       med=878.85µs max=198.8ms  p(90)=32.43ms  p(95)=136.6ms
     http_req_duration..............: avg=611.73ms min=487.28µs med=189.3ms  max=13.15s   p(90)=938.17ms p(95)=1.61s
       { expected_response:true }...: avg=611.73ms min=487.28µs med=189.3ms  max=13.15s   p(90)=938.17ms p(95)=1.61s
     http_req_failed................: 0.00%   ✓ 0         ✗ 3229
     http_req_receiving.............: avg=111.64ms min=14.56µs  med=7.67ms   max=5.22s    p(90)=373.34ms p(95)=608.14ms
     http_req_sending...............: avg=46.12µs  min=13.66µs  med=47.86µs  max=120.09µs p(90)=57.62µs  p(95)=61.6µs
     http_req_tls_handshaking.......: avg=19.76ms  min=0s       med=4.51ms   max=289.05ms p(90)=94.07ms  p(95)=139.91ms
     http_req_waiting...............: avg=500.04ms min=424.27µs med=140.82ms max=13.13s   p(90)=710.21ms p(95)=1.2s
     http_reqs......................: 3229    79.957096/s
     iteration_duration.............: avg=693.62ms min=1.52ms   med=225.59ms max=13.16s   p(90)=1.1s     p(95)=1.77s
     iterations.....................: 3001    74.311317/s
     vus............................: 0       min=0       max=83
     vus_max........................: 600     min=600     max=600
Updating my options to attempt to reach 200RPS, and I can see that my test was able to reach ~140RPS. Still not meeting the target of 200RPS, but hopefully it shows that my environment is capable of at least 100RPS.
  scenarios: {
      duration: '30s',
      rate: 200,
      timeUnit: '1s',
      maxVUs: 1200,
  execution: local
     output: dashboard
           * average_load_test: 200.00 iterations/s for 30s (maxVUs: 600-1200, gracefulStop: 30s)
     █ teardown
     checks.........................: 100.00% ✓ 6001       ✗ 0
     data_received..................: 3.1 GB  68 MB/s
     data_sent......................: 21 MB   458 kB/s
     http_req_blocked...............: avg=31.55ms  min=200ns    med=5.53ms   max=703.16ms p(90)=96.46ms  p(95)=276.08ms
     http_req_connecting............: avg=11.54ms  min=0s       med=873.24µs max=215.31ms p(90)=31.19ms  p(95)=94.71ms
     http_req_duration..............: avg=648.77ms min=503.62µs med=203.51ms max=24.85s   p(90)=980.87ms p(95)=1.58s
       { expected_response:true }...: avg=648.77ms min=503.62µs med=203.51ms max=24.85s   p(90)=980.87ms p(95)=1.58s
     http_req_failed................: 0.00%   ✓ 0          ✗ 6438
     http_req_receiving.............: avg=104.7ms  min=13.98µs  med=7.56ms   max=10.14s   p(90)=340.7ms  p(95)=608.45ms
     http_req_sending...............: avg=44.12µs  min=10.57µs  med=45.54µs  max=917.9µs  p(90)=56.24µs  p(95)=60.47µs
     http_req_tls_handshaking.......: avg=19.45ms  min=0s       med=4.54ms   max=701.72ms p(90)=55.11ms  p(95)=139.57ms
     http_req_waiting...............: avg=544.03ms min=434.18µs med=149.12ms max=24.84s   p(90)=757.64ms p(95)=1.26s
     http_reqs......................: 6438    141.161241/s
     iteration_duration.............: avg=730.82ms min=1.28ms   med=243.92ms max=24.85s   p(90)=1.15s    p(95)=1.72s
     iterations.....................: 6001    131.579466/s
     vus............................: 0       min=0        max=152
running (0m45.6s), 0000/0600 VUs, 6001 complete and 0 interrupted iterations
average_load_test ✓ [======================================] 0000/0600 VUs  30s  200.00 iters/s
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   999  100   921  100    78   3177    269 --:--:-- --:--:-- --:--:--  3444
Or, if I use the constant-vus executor, I’m able to reach ~220RPS. There are some non 200 responses on this test, but it was the same test, and hopefully (again) shows that my environment is capable.
  scenarios: {
      executor: 'constant-vus',
      vus: 200,
      duration: '15s',
  execution: local
     output: -
  scenarios: (100.00%) 1 scenario, 200 max VUs, 45s max duration (incl. graceful stop):
           * average_load_test: 200 looping VUs for 15s (gracefulStop: 30s)
     ✗ response code was 200
      ↳  90% — ✓ 4600 / ✗ 478
     checks.........................: 90.58% ✓ 4600       ✗ 478
     data_received..................: 2.4 GB 101 MB/s
     data_sent......................: 16 MB  679 kB/s
     http_req_blocked...............: avg=40.82ms  min=215ns    med=5.29ms   max=1.06s    p(90)=99.13ms  p(95)=280.91ms
     http_req_connecting............: avg=12.83ms  min=0s       med=868.42µs max=255.41ms p(90)=34.96ms  p(95)=136.66ms
     http_req_duration..............: avg=576.89ms min=482.56µs med=172.95ms max=14.46s   p(90)=1.27s    p(95)=1.86s
       { expected_response:true }...: avg=614.5ms  min=482.56µs med=205.92ms max=14.46s   p(90)=1.29s    p(95)=1.89s
     http_req_failed................: 8.75%  ✓ 478        ✗ 4984
     http_req_receiving.............: avg=102.99ms min=13.17µs  med=5.75ms   max=7.11s    p(90)=341.21ms p(95)=606.96ms
     http_req_sending...............: avg=178.36µs min=9.83µs   med=45.45µs  max=737.38ms p(90)=57.42µs  p(95)=61.99µs
     http_req_tls_handshaking.......: avg=25.71ms  min=0s       med=4.17ms   max=1.06s    p(90)=94.87ms  p(95)=140.61ms
     http_req_waiting...............: avg=473.72ms min=421.78µs med=142.12ms max=14.26s   p(90)=923.98ms p(95)=1.57s
     http_reqs......................: 5462   226.459655/s
     iteration_duration.............: avg=664.61ms min=997.36µs med=217.89ms max=14.47s   p(90)=1.36s    p(95)=2.07s
     iterations.....................: 5078   210.538654/s
     vus............................: 1      min=1        max=200
     vus_max........................: 200    min=200      max=200
Is there something obvious that I’m missing, or misunderstanding about this executor?
I really appreciate any/all help that you can provide :slightly_smiling_face:
Hi @chrispenny, welcome to the community forum!
I think it must be a calculation issue, because if your test lasts 30 seconds and performs 3001 iterations, that is almost exactly 100 iterations/sec.
Maybe the situation is, that k6 starts 100 iterations/sec and it waits all the iterations to finish. From the summary it can be seen, that there were iterations that lasts more than 13 seconds. The whole test may last for 43 seconds, and if k6 calculates the rate as iterations count divided by the whole test run time, then it should be 69.7 iterations/second
Aaah interesting! Wow, yea, I feel a /facepalm coming on as I didn’t even think to manually calculate the RPS - I went straight to the number k6 had calculated.
Something I’ve noticed is that there is some idle time at the end of the test, where (I think) k6 is generating this output screen for me. I wonder if it includes that time when it calculates the overall RPS.
Thanks, @bandorko :slightly_smiling_face: You’ve saved me a bunch of extra head scratching!
@chrispenny
The summary screen generation is just a couple millisec, but there is a graceful stop period, while k6 will let all the iterations to finish. This time is calculated into the overall RPS
Watching the test a bit more closely. You’re absolutely right, that’s exactly what’s happening.
Thanks again!
