What Grafana version and what operating system are you using? homeassistant, Grafana v10.4.1
What are you trying to achieve? data from homeassistant
How are you trying to achieve it? influxbd
What happened? InfluxDB returned error: error reading influxDB
What did you expect to happen? that i can import data from influxbd
Can you copy/paste the configuration(s) that you are having problems with? login on influxdb
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. No
Did you follow any online instructions? If so, what is the URL? (Install InfluxDB on Proxmox for Home Assistant - SmartHomeScene)
Problem solved. can by closed. Greetings smytangel
How was it solved so that it benefits others
