Hi, I’d like to set up a Linux server agent.
My problem is that the two configs on the website and the one installed by the shell command are different.
This is what the website tells me:
integrations:
node_exporter:
enabled: true
relabel_configs:
- replacement: abcd
target_label: instance
logs:
configs:
- name: integrations
scrape_configs:
- job_name: integrations/node_exporter_journal_scrape
journal:
max_age: 24h
labels:
instance: abcd
job: integrations/node_exporter
relabel_configs:
- source_labels: ['__journal__systemd_unit']
target_label: 'unit'
- source_labels: ['__journal__boot_id']
target_label: 'boot_id'
- source_labels: ['__journal__transport']
target_label: 'transport'
- source_labels: ['__journal_priority_keyword']
target_label: 'level'
And this is what the agent installed by default in /etc/grafana-agent.yaml:
integrations:
node_exporter:
enabled: true
relabel_configs:
- replacement: hn2
prometheus_remote_write:
- basic_auth:
password: qwerty
username: 123456
url: https://prometheus-prod-01-eu-west-0.grafana.net/api/prom/push
logs:
configs:
- clients:
- basic_auth:
password: qwerty
username: 234567
url: https://logs-prod-eu-west-0.grafana.net/loki/api/v1/push
positions:
filename: /tmp/positions.yaml
scrape_configs:
journal:
labels:
instance: hn2
max_age: 24h
relabel_configs:
- source_labels:
- __journal__systemd_unit
target_label: unit
- source_labels:
- __journal__boot_id
target_label: boot_id
- source_labels:
- __journal__transport
target_label: transport
- source_labels:
- __journal_priority_keyword
target_label: level
- job_name: integrations/node_exporter_direct_scrape
static_configs:
- labels:
__path__: /var/log/{syslog,messages,*.log}
instance: hn2
targets:
- localhost
target_config:
sync_period: 10s
metrics:
configs:
remote_write:
- basic_auth:
password: qwerty
username: 345678
global:
scrape_interval: 60s
Which one should I use? The one on the website seems not to have any secret strings, so I guess the /etc/grafana-agent.yaml one is better. But then what is the website trying to say?
