I’m running Grafana and Prometheus successfully on my microk8s cluster. I’m now trying to setup Loki. It’s mostly working, however I’m still unable to configure the local filesystem. I’m using the loki-stack helm charts to deploy.
Here is what I did:
helm repo add grafana https://grafana.github.io/helm-charts
helm repo update
helm upgrade --install loki grafana/loki-stack -f loki-values.yaml
And here is the content of loki-values.yaml:
loki:
auth_enabled: false
commonConfig:
replication_factor: 1
storage:
type: filesystem
commonStorageConfig:
type: filesystem
rulerConfig:
storage:
type: local
storage_config:
filesystem:
directory: /home/djipey/loki
singleBinary:
replicas: 1
persistence:
enableStatefulSetAutoDeletePVC: false
storageClass: local-loki
enabled: true
promtail:
config:
snippets:
pipelineStages:
- docker: {}
- cri: {}
- json:
expressions:
level: level
path: path
ts: ts
time: time
status: status
method: method
latency: latency
- labels:
level: ''
path: ''
status: ''
method: ''
- timestamp:
source: ts
format: RFC3339Nano
enabled: true
For loki’s PV:
apiVersion: v1
kind: PersistentVolume
metadata:
spec:
accessModes:
- ReadWriteOnce
capacity:
storage: 10Gi
hostPath:
path: /home/djipey/loki
type: DirectoryOrCreate
storageClassName: local-loki
The dir /home/djipey/loki exists on the machine and I chmoded it 777 so I don’t expect any permission issues.
The setup above works, and I can create a Loki data source in Grafana, and it contains the data I expect. However, the loki folder stays empty. A describe on the loki pod hints that the storage config is ignored:
Volumes:
tmp:
Type: EmptyDir (a temporary directory that shares a pod's lifetime)
Medium:
SizeLimit: <unset>
config:
Type: Secret (a volume populated by a Secret)
SecretName: loki
Optional: false
storage:
Medium:
SizeLimit: <unset>
kube-api-access-w5tz2:
Type: Projected (a volume that contains injected data from multiple sources)
TokenExpirationSeconds: 3607
ConfigMapName: kube-root-ca.crt
ConfigMapOptional: <nil>
DownwardAPI: true
But it doesn’t work, the PV is never claimed and the loki folder on my machine stays empty. I have been at it for 2 days now and I can’t get it to work.
Here are the versions I’m using:
❯ helm list
NAME NAMESPACE REVISION UPDATED STATUS CHART APP VERSION
kube-prometheus-stack monitoring 14 2023-05-18 00:06:08.505163787 +0100 BST deployed kube-prometheus-stack-45.28.1 v0.65.1
loki monitoring 8 2023-05-19 11:55:18.176228629 +0100 BST deployed loki-stack-2.9.10 v2.6.1
prometheus-postgres-exporter monitoring 3 2023-05-17 23:36:51.728690574 +0100 BST deployed prometheus-postgres-exporter-4.4.3 0.11.1
Would you have any idea how to configure that please?
