I’ve deployed the helm chart grafana/loki 5.42.2. All k8s nodes does not have configured a default container image registry like docker.io, for this reason, the container images must be named fully qualified.
Instead to run into the pull limit rate of docker.io, I configured a custom container image registry by overwriting the registry: properties of the helm chart.
After deploying the chart, I noticed that the pods loki-logs continues into the ImageSpecError state with the following message:
Failed to inspect image "grafana/agent:v0.39.1": rpc error: code = Unknown desc = short-name "grafana/agent:v0.39.1" did not resolve to an alias and no unqualified-search registries are defined in "/etc/containers/registries.conf"
I tried to find out how I can configure the fully qualified container image name as part of the helm chart, but there is no configuration option to set the image registry.
How can I configure for the container image grafa/agent of the pod loki-logs a custom registry?
Furthermore, a GitHub issue is already existing. I will append the Link in a next comment, because for new users it is not possible to add more than one link in a comment.
Volker
