Configuration grafana
Bonjour
en faite je ne parviens pas ajouter data source il m’envoie http error et bad gateway comment resoudre cet problème oubien si je peux avoir une assistance a distance svp
email:isbban@gmail.com
I don’t speak French but google translate says you are having problems with adding a data source. Can you take a screenshot of the data source page? The problem is that it cannot find your data source (bad gateway).
Hello
Please, I can have assistance for your software. If you can assist remotely
for the configuration we want to use for the monitoring of our network
system
Thank you
BANGOURA IBRAHIMA SORY | INGÉNIEUR INFORMATICIEN
TEL: 621-839-315 | 666-462-345 | 657-172-470
EMAIL: isbban@gmail.com
For that type of support, then you should look at our support plans: https://grafana.com/services/support
Otherwise, I can answer questions here.
