Conditional query?
I have two templated variables - one for host and other for VM. The templated variables is such that when I select the host, I get VMs in the next variable present in that host. So I will have to select the host to select the VMs.
What I want : When I select the host, I need to get values of the host and when I select VM, I need ti get VM values. I tried using OR condition but it added the values since the host variable has value in it. Is there any condition I can use in the queries ?
select value from ofstat_value where type_instance = ‘latency’ and host =~ /$host_id$/ or host =~ /$vm_id$/
I tried group by as well, it did work with latency by giving additional values (which I don’t need). For iops, the values aren’t right.
Data Source - Influxdb
Any help is appreciated.
Is there a tag you can distinguish between VMs and hosts? Then you can create a variable “hosttype” that you can use in your host variable query.
http://play.grafana.org/dashboard/db/influxdb-templated-queries?orgId=1
No, both are under the host tag. The relationship is through another column. Below is the part of the schema -
host =========== relation=============== type =============value
VM_1=========compute_1===============iops ============={some_value}
VM_2=========compute_1=============== latency============{some_value}
VM_3=========compute_2===============iops ============={some_value}
compute_1=====compute_all ===============iops ============={some_value}
compute_2=====compute_all=============== latency============{some_value}
compute_all=====null ====================iops ============={some_value}
But that is exactly what I said, there is another tag to distinguish them, exactly like the datacenter and host variables in the dashboard I linked to.
