Compatibility of Old version of k6 Docker images for running k6
Currently I am using loadimpact/k6:0.30.0 as the docker image to run k6 using docker. Is loadimpact not supported now?
Anyway I am currently using the above and did not face much issues with that. Just want to check whether there can be any impact if we continue to use this dockerimage.
Hi @sahaniperera995 !
No, maintenance of the loadimpact/k6 stopped at the end of last year. We don’t push any new versions there.
So, no new k6 functionality will be available. I recommend migrating to the grafana/k6.
Cheers!
Thank you.
