When I set a range like "IBM!A:C it returns columns A,B,C rather than just A, C? What am I missing here?
TX,
David
TX,
David
Hi @davidjayjackson,
Welcome to the
community support forums !!
Regarding your question, this can be achievable by using Transformation and in this particular case “Filter data by name” as explained in the documentation.
I hope this helps.
Thanks for your reply.
Well, I guess that will have to do till the bug is fixed.
I will just mention that I am not having the same problem with SQL Server i.e. The date range tool in the top right corner of the dashboard isn’t working…
Thanks again,
David
Let me have a look into that one and will see if I can help out ![]()
