Hi All,
Is there any possibility to create customize Time Range Filter like a table in left side ?
Thanks in advance
Regards
Siva Prasad
Hi All,
Thanks in advance
Regards
Siva Prasad
please follow the below screen shot
There’s no support for changing the content of the quick ranges if that’s what you’re asking for. Selecting absolute ranges like your screenshot above is supported.
HI mefraimsson,
primarily thanks for replying . My question is , is it possible to place in left side of Dashboard (i.e is possible Customization)
Thanks
Maybe, if you change grafana source code
