Trying to do a fresh install on Ubuntu 18.04.3 LTS. These are the steps I’ve completed so far:
curl https://packages.grafana.com/gpg.key | sudo apt-key add -
sudo add-apt-repository "deb https://packages.grafana.com/oss/deb stable main"
sudo apt-get update
sudo apt-get install grafana
And this is the error the install gives:
chown: cannot access '/etc/grafana/*': No such file or directory
dpkg: error processing package grafana (--configure):
installed grafana package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
grafana
What does
apt policy grafana
show? If it shows lots then the first 10 lines will do. Copy/paste it here please.
grafana:
Installed: 6.3.2
Candidate: 6.3.2
Version table:
*** 6.3.2 500
500 https://packages.grafana.com/oss/deb stable/main amd64 Packages
100 /var/lib/dpkg/status
6.3.1 500
6.3.0 500
6.2.5 500
6.2.4 500
6.2.3 500
6.2.2 500
6.2.1 500
6.2.0 500
6.1.6 500
6.1.5 500
6.1.4 500
6.1.3 500
6.1.2 500
6.1.1 500
6.1.0 500
6.0.2 500
6.0.1 500
6.0.0 500
5.4.4 500
5.4.3 500
5.4.2 500
5.4.1 500
5.4.0 500
5.3.4 500
5.3.3 500
5.3.2 500
5.3.1 500
5.3.0 500
5.2.5 500
5.2.4 500
5.2.3 500
5.2.2 500
5.2.1 500
5.2.0 500
5.1.5 500
5.1.4 500
5.1.3 500
5.1.2 500
5.1.1 500
5.1.0 500
5.0.4 500
5.0.3 500
5.0.2 500
5.0.1 500
5.0.0 500
4.6.5 500
4.6.4 500
4.6.3 500
4.6.2 500
4.6.1 500
4.6.0 500
4.5.2 500
4.5.1 500
4.5.0 500
4.4.3 500
4.4.2 500
4.4.1 500
4.4.0-pre1 500
4.4.0 500
4.3.2 500
4.3.1 500
4.3.0 500
4.2.0 500
4.1.2-1486989747 500
4.1.1-1484211277 500
4.1.0-1484127817 500
4.0.2-1481203731 500
4.0.1-1480694114 500
3.1.1-1470047149 500
3.1.0-1468321182 500
3.0.4-1464167696 500
2.6.0 500
That looks ok. I haven’t got an 18.04 system but I have checked it installs ok on 19.04.
Is there anything unusual about your 18.04 installation? Is it in a VM for example? Docker? Anything else unusual?
Does the directory /etc exist?
Does the directory /etc/grafana exist? If it does, what does this command show?
ls -al /etc/grafana
It is a VM. What is weird is that I have a sister VM of this machine and everything installs just fine over there. I’ve tried manually creating the empty folder in /etc/grafana and setting permissions but it still fails. If I can’t figure this out I’m going to try upgrading to Ubuntu 19.04 and/or SCP copy from the sister machine to see if I can get things working that way.
Update
I upgraded to Ubuntu 19.04, which afterwards I had to re-add the grafana apt-repository again but still no luck in installing Grafana.
same error. Next step is going to be looking at manually copying directories over and setting permissions manually.
I think you have something seriously amiss with your system. Are you able to install other packages ok?
I have the same issue. I use Ubuntu 18.4.
How dit you solve it?
I ended up completely rebuilding my VM. I couldn’t solve/explain the issue I was facing.
I have found a solution. The problem was that my VM didn’t had the permissions to create the missing configuration files.
I have solved it with the --force flag of dpkg. My command was:
dpkg --force-all -i grafana_6.0.0_amd64.deb
