Since this weekend I’ve installed InfluxDb and Grafana, which are using data from Domoticz.
My question is about a graph for gas usage. The data I get is every hour the gas meter value.
In the normal graph for the last 24 hours I use diff() to see the difference between 2 values to know the usage for that hour.
I now want to move the graph to a Montly view were I summarize the hourly value of a day to a total for that day during the month.
Example: yesterday the gas usage was about 0,5m3 per hour, so the total of that day would be 6m3 to be displayed in the Monthly view.
Same story of course for a Graph per year, where you want to display the totals of a month.
In other post I read something like summarize or sum().
The sum() does not work in combination with the diff() function. When I remove the diff() the it takes the sum of the gas meter values.
With the summarize function I doubt if it works with InFlux.
Does anybody have any advice?
Thanks
