I try to install k6 in gke and it will pull images for: Package k6-operator · GitHub, but fail to pull.
1, I check grafana/k6-operator in artifacthub
and find manager.image.registry can be changed successfully
2, but for initializer, in code, seems hardcoded.
so my question is how to change the registry for initializer just like I do for manager:
helm install k6-operator grafana/k6-operator --set manager.image.registry=“docker.io”
thanks a lot.
