I’m running the Operator model and ran into this limitation with using a PVC and switched gears to making my own image with my custom modules already provided.
My issue is that I cannot get the Runner (and most likely Starter) pods to authenticate to my private registry. In K8 i would normally use the following but it fails since the field isn’t defined in the CRD.
runner:
imagePullSecrets:
- secretName
How do I use private a Private Registry for my Runners/Starters (and initializer)?
I believe this issue is a feature request and thanks for pointing it out!
@olha - im who opened that request
since i cannot use a custom image in the operator model, do you know of a successful pattern for running K6 without the operator in Kubernetes?
@nema.darban that would be re-inventing the wheel
IMHO, it’s much quicker to add support for imagePullSecrets
to k6-operator. Have you tried doing that? It sounded as if you might have… If so, please feel free to open a PR.
I’ve been trying to get imagepullsecrets working so i can open a pull request but I’m missing something.
I’ll open one anyways and see if a contributor can point me in the right direction.
