Change how the traceroute command executes
I would like to know if is there a way to change how the traceroute command is executed, because I need to send the packages with TCP, not ICMP, due to the endpoint I want to reach has blocked ICMP communication, but I can reach it if I try the command manually: sudo traceroute xxxx -p 443 -T
