Change column height in table
original topic was closed, couldnt reopen it, here is the issue:
"Hello,
i have a table in grafana (based on SQL query), and need to split the header display name with new lines, for example :
original header name:
“aa_bb_cc”
wanted header name:
“aa
bb
cc”
is it possbile in grafana ?
thanks"
got a replay with suggestion :
"which database?
most db’s have a substring function where you can extract portions of strings based on position and separator characters, so using the underscore to substring aa_bb_cc into 3 columns. then you can pivot your data from columns into rows, so it’s possible to use the database to do the work and not grafana"
this suggestion doesnt satisfy our needs, since the goal is to still use one column, but to change the colomn header hight, so that the coloumn appears “thiner”
this is not possible without custom css, but take a look at the Dynamic Text plugin for more configuration options
