I am getting the following error
I am trying to change the admin password (since I’m not able to log in with the password I set before) using this command:
grafana-cli admin reset-admin-password
https://community.grafana.com/t/admin-password-reset/19455
Any help would be much much appreciated! THANK YOU
I tried changing the read-write properties of the db file but now it is showing this error!
Hi @saymeowmeow ,
You are missing one “-” when writing homeopath.
So currently you have -homepath but it should be --homepath
Give it a try and hopefully it will work
Ok, try to run the command in this specific order once you are at your path:
C:\Progam Files\GrafanaLabs\grafana\bin>
then run below:
grafana-cli admin reset-admin-password --homepath "c:\Program Files\grafana" mynewpassword
Let us know if this works.
