I’m trying to create a dynamic dashboard that can redirect users to Loki logs. So there is a panel that shows 5xx responses and I want to add a data link that points to the logs. We are using Prometheus to monitor the HTTP requests and I’m using the Prometheus ENV variable to set the data source on the dashboard. Is there a simple way to connect the selection of our Prometheus env to the Loki Env. When I select Prom-Prod, automatically the Loki-Prod variable is chosen.
I’m using Grafana v9.0.4
