Canvas - Animated electric cable
    Docker image: grafana/grafana:9.4.0
    I’m working on a Canvas and i’m trying to add animated electric cable like in the example in the documentation:
    https://grafana.com/static/img/docs/canvas-panel/canvas-metric-value-9-2-0.mp4
    I don’t know if it’s an element that I can use like a connection, or if it’s a gif that is used for the example.
    I don’t found any way to achieve it, maybe with the style of the connection between element
    This is the Canvas documentation that I follow:
    Canvas | Grafana documentation
Does anyone have any idea how I can achieve this?
Use background image with animation - gif was used in this particular case. See: Grafana
@leolb06 You can create your own dynamic and animated elements for the canvas panel, but they require you to add new advanced components and built your own version of Grafana.
We explained how in the blog post:
