I’m developing a React-based panel plugin using webpack (based on grafana-plugin-template-webpack). The React part works, however if I try to include react-redux into the plugin I get the following error message:
Uncaught (in promise) Error: Unable to dynamically transpile ES module
A loader plugin needs to be configured via `SystemJS.config({ transpiler: 'transpiler-module' })`.
The following code causes the issue:
import {connect} from 'react-redux'
Webpack config:
module.exports = {
target: 'node',
context: resolve('src'),
entry: './module.js',
output: {
filename: "module.js",
path: resolve('dist'),
libraryTarget: "amd"
externals: [
'jquery',
'lodash',
'moment',
function (context, request, callback) {
var prefix = 'grafana/';
if (request.indexOf(prefix) === 0) {
return callback(null, request.substr(prefix.length));
callback();
plugins: [
new webpack.DefinePlugin({
"process.env": {
NODE_ENV: JSON.stringify("production")
new webpack.optimize.OccurrenceOrderPlugin(),
new CopyWebpackPlugin([
{ from: 'plugin.json' },
{ from: 'partials/*' }
resolve: {
alias: {
'src': resolve('src')
module: {
rules: [
test: /\.js$/,
exclude: /(external)/,
use: {
loader: 'babel-loader',
query: {
presets: [
"@babel/preset-env",
"@babel/preset-react"
].map(require.resolve),
Can anybody give me a hint what I’m doing wrong?
