Can't set Query on right side axis placement
    8.02
Hi, i use the latest Version from Grafana. In older Versions i can set a value on the right side of the y-axis
In Grafana 8 it’s not working. I have set an override for Axis > Placement to the Right side but this will not change.
Any Idea?
Regards
Hermann
override the standard - unit as well,
somehow, it has to be a different unit to make Y2, Y3, Y4 etc work
Thx. Works fine now.
