After the reverse proxy is activated, unable to login. login page shows incorrect credentials.
apache conf :
grafana conf :
Is the reverse proxy on the same server as Grafana? If not I would try to connect with the local grafana server ip and port and verify you credentials are working as expected.
NVM… see localhost .
yes reverse proxy is on same server.
