Grafana v9.5.21 (2dd6ebef03fbe42927769bf00bcf0bc4e621bb9c)
- What are you trying to achieve?
I need to inner join three tables:
Table A
a_id | name
Table B
b_id | a_id | price
Table C
c_id | b_id | owner
- How are you trying to achieve it?
- Add a
Join by fieldtransformation - Select the
INNERMode for the transformation - Select the
a_idvalue - Add one more
b_idvalue
- What happened?
There is no owner column in the result table.
A table that looks similarly to the following:
Result Table
a_id | name | b_id | price | c_id | owner
- Can you copy/paste the configuration(s) that you are having problems with?
No
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No, did not receive.
- Did you follow any online instructions? If so, what is the URL?
