Can't find the path of the test report
Hi Team,
I’m running a test on docker, but the html report i generated missing on the docker volume I mounted.
I refer the below thread and run the test based on the details shared on the thread.
docker run -it --user “$(id -u $USER)” -e “TEST_PROFILE=${TEST_PROFILE}” -v ${CODEBUILD_SRC_DIR}/src:/src --workdir “/src” -i loadimpact/k6 run --out influxdb=http://influxdb:8086/grafana /src/tests/app1/index.js
Test runs perfectly, and it shows the generating summary report but still i can’t find the report.
Hi @Gerard!
I checked using a minimal example:
import { sleep } from "k6";
import http from 'k6/http';
import { htmlReport } from "https://raw.githubusercontent.com/benc-uk/k6-reporter/main/dist/bundle.js";
export default function () {
  http.get("http://test.k6.io");
  sleep(1);
export function handleSummary(data) {
  return {
      './summary.json': JSON.stringify(data),
      "./summary.html": htmlReport(data),
And it seems to work :thinking:
After executing a command on my local machine:
docker run -it --user "$(id -u $USER)" -v $(pwd):/src --workdir "/src" -i grafana/k6 run /src/script.js
There are two reports generated:
├── script.js
├── summary.html
└── summary.json
So, I suggest trying to experiment with this to understand where the issue can be.
Cheers
Thanks @olegbespalov,
Yes from my end --workdir not set to /src folder, therefore the report not generated inside the /src/ folder. I found out the default workdir for k6 docker set to /home/k6/ and all the reports were generated there.
:clap:
