Cloud (Free) at the moment -
We have a process that logs a single entry each time it successfully does something with error_code = 0, or if there’s an error during an attempt: error_code = 4. Typically this results in potentially thousands of logs per hour across all machines. We’re parsing those logs and sending them to Loki as json logs.
I’m trying to show how many units are produced per hour across all machines using count_over_time. Is there a better way to do this?
count_over_time({service_name=“robot-logs”} | json | error_code =0
[$__auto]) -
What happened?
(Trace ID: 333680631c5d3b850a95bcdb3885a65b)
I expected to see a time series display of how many logs with error_code = 0 exist in each hour bucket. -
* Did you follow any online instructions? If so, what is the URL?
